Having the full system should mean the valve servo motor has been isolated/removed(unlikely) Check to see if it has an eliminator fitted. It should have. If servo motor still in situ, check if cable attached and it moves when switching on ign. You can check these things before handing over ££’s to your local dealer. Some people have fitted small spring on end of servo cable to trick ecu. Make sure any of the above are checked first. Servo motor is below seat right side sitting on bike. Servo power cable is in there too but awkward to access.
