1260 Multistrada Servicing Costs
Discussion in 'Multistrada' started by Longdog, Oct 11, 2021.
  1. FYI - My costs for a 18K + Annual service. Performed by a Ducati authorized dealer in NJ USA
    18,000 MILE SERVICE W/ ANNUAL
    - CHANGE ENGINE OIL AND FILTER
    - CHECK VALVE CLEARANCE, ADJUST IF NEEDED (BILLED ADDITIONALLY)
    - REPLACE AND ADJUST TIMING BELTS
    - REPLACE SPARKPLUGS
    - REPLACE AIR FILTER
    - CHECK AND ADJUST BRAKE AND CLUTCH CONTROLS IF NECESSARY
    - CHANGE COOLANT AND CHECK FAN OPERATION WHERE APPLICABLE
    - CHANGE CLUTCH AND BRAKE FLUIDS
    - CHECK AND ADJUST TIRE PRESSURES
    - CHECK AND ADJUST CHAIN TENSION, LUBRICATE IF NECESSARY
    - CHECK BRAKE PADS AND ROTORS FOR WEAR
    - CHECK BATTERY CHARGING SYSTEM
    - TEST SIDESTAND SWITCH FOR PROPER OPERATION
    - PERFORM BOLT TORQUE CHECK AT CRITICAL POINTS
    - CHECK LIGHTS AND SWITCHES FOR PROPER OPERATION
    Part # Qty Description Price Total
    42610341B 1.00 FILTER, AIR $66.99
    73740342A 2.00 TIMING DRIVE TOOTHED BELT $149.98
    85250421A 1.00 WASHER 12,2X18X1,5 1098/08 $1.50
    78811341B 2.00 GASKET $7.00
    78811331B 2.00 VALVE COVER GASKET EXTERNAL $25.00
    67040451A 4.00 SPARK PLUG NGK MAR9A-J $198.00
    81220142156 1.00 BRAKE FLUID DOT 4 $4.99
    44440038A 1.00 FILTER, OIL $23.99 $0.00 $23.99
    550047150 4.00 SHELL ADVANCE 15W50 $71.96
    90130013B 3.00 LIQUIDO ENI ANTIFREEZE BIKE S $49.47
    88642621A 12.00 O-RING $18.00
    Parts Parts Subtotal $616.88
    Labor PERFORM 18K WITH ANNUAL Labor Subtotal $1,470.00
    Job Subtotal $2,086.88
  2. I'm taken by the cost of the spark plugs! $198 for four!!:(
  3. I feel the same way, I have a 3 year old M1200.
    As long as you are happy with the service light on permanently, as the dealers don’t want to cancel it without the service attached.
  4. I supplied my spark plugs. I was warned that they would cost £26 each, so I went on ebay and bought all four for £43. The dealer didn't mind as he would have supplied them at cost price.
  5. exactly!... I think Rak was well and truly spanked there!
  6. About £100 for 4 in the UK.
    Usd198 = £150, well ripped off
  7. What can I say, they had me by the short and curlies. I guess you have to pay to play :)
  8. Current UK dealer prices are:
    Oil filter £14
    Fuel filter £45
    Air filter £41
    Spark plugs X4 £120
