Yeah i read about them in MCN when they put them on there 899 test bike and only had good things to say.... looking forward to trying them out
Do they come without sprockets etc? If so what sprocket do you need to get, is it an 899 one of a specific bst bolt pattern? Also front disc wise, is it literally a case of fitting the stock discs on or do u need new ones? I'm seriously tempted once i get Christmas out the way to get a set now that I've gone off gold, thinking if u are going to go for weight saving, may as well go with the lightest u can Sent from my iPhone using Tapatalk
The only thing you will need is a rear sprocket and may well be in with the wheels but ask the question,mine did not come with a rear sprocket,all bst wheels use the same pcd Talon Sprockets for BST Carbon Fiibre Mototrcycle Wheels
Hi Mate They come with everything you need to fit them inc a rear talon sprocket, the discs will swap straight over but I would get some new disc fixing bolts as the Ducati ones are made of chocolate. The only other thing to swap over is the Cush rubbers. I wouldn't bother with the ceramic bearings as I was told you couldn't really notice the difference for the cost. If you buy a set you won't regret it they really do make a massive difference and I'd take BST wheels over an exhaust etc any other mod they are that good!
Thanks mate, much appreciated. I assume normal tyre fitters are okay with carbon wheels? Sent from my iPhone using Tapatalk
