My Take On 996/1098 Mongrel Build!
Discussion in 'Builds & Projects' started by doogalman, Nov 13, 2016.
  1. Nice work, Roy!
  2. With tank off and motor running they are rock solid. They have been used all year and having had the tank off a few days ago everything is as it should be. They are made in stainless 1.2mm
    Previously I had the injectors mounted onto a bracket that was mounted between the two intakes and that suffered from vibration. Hence why I changed it and simplified it.
  3. Simple is almost always better. :upyeah:
