1200 DVT Navihalter Gps Mount
Discussion in 'Multistrada' started by Marc Mellor, May 9, 2017.
  1. Hang on a minute
  2. ebay item No
    322665087074
    Seller assumes all responsibility for this listing. just type No in search
  3. Let me know if you got it.
  4. Excellent Stevie, thank you.
  5. Have you bought it.
  6. No Stevie, read it properly and realized it's for a Garmin not a Tomtom.
  7. I’d love to check it out since broke isn’t taking it but I can’t find it. Searched for the auction number but it doesn’t come up. Any chance you can send an actual link please?
  8. I just copied the number and pasted it in the EBay uk only search bar and it took me straight there Anthony.
  9. Bit confused about your reply BROKE. As the mount can be modified to take any sat nav its only 4 holes in a plate. You could even make a new plate for it. If you are a handy type of DIY type.
  10. I found and checked out the auction, looks like he drilled a hole in it and some of the parts or screws are missing. I decided to pass and will leave the one I currently have on there. It's working perfectly fine I just wish I didn't have to make my own mount to affix my Garmin 595. Ducati sucks for making this only fully compatible with their overpriced 395 version.
  11. The actual mount has only 1 screw on it with a rubber compressible plug on the back. Its basically stuck to the bike screen adjuster with 2 sided tape. They do shake about a bit. My sat nav came with all the mounting screws in the packet.
  12. I noticed yesterday that you can cure the wobbling by putting your finger between the nav mount and screen. I can then actually read the Satnav! I reckon that is why my bike has the cruise control fitted?
    I'm going to try Velcro fixing a block of rubber/foam at the back of the mount, to press against the screen (not much pressure required) and see if that helps?
  13. It might help but the bike is an L twin after all. Lets know if it works.
  14. Hi Anthony ,
    I had te same problem , but there is a shop here in belgium and they make a little adapterplate to fit the Garmin 595
    It costs 15€ and problem fixed.
    Their website is https://www.waypointzolder.be/accessoires/motorsteunen/GAGTBA06-aanpassingsset-zumo-3xx.php
