I do and have worked in the nuclear industry and have had involvement with N.D.T. radiography and until things go catastrophically wrong....I'd be more concerned about the microwave in the kitchen or the mobile stuck to your head! Now where did I leave them Potassium Iodide capsules????
Lucaz, get a solar panel and a boat battery. Hook them up to an inverter and you've got mains power and the ability to run 12V LED lights. Job done.
As big as you can afford Mine is maybe 3 feet by 2. Can't remember the output. Look online for specialists. They're not as expensive as you'd think
Thx will look in to it, is yours in any way attached to the roof? Do you even have it in garage? Asking as I am renting so minimal possible work is needed.
yes, I drilled a couple of holes for screws and ran the wires in through the corrugated roof. Then I sealed it with builders foam. Easy. And fun too : ) The garage this is in leaks anyway, so the holes in the roof will not make it leak any more.
