New E10 Fuel Compatability?
Discussion in 'Ducati General Discussion' started by zooptee, Jul 19, 2021.
  1. I know it has alcohol added but please stick to whiskey. :)
  2. Thanks but I'll stick to whisky. Not that fake irish pish.
  3. just for you bootie
  4. Informative. Thank you for posting :upyeah: Andy
  5. Thin Lizzy more fake irish. This time fake irish rock.
  6. Well it is a cover of an Irish folk song, so not much rock even with Gary Moore on guitar.
  7. Not really a fan of either Thin Lizzy or Gary Moore. Dont get me wrong, I wont dismiss them, just doesnt do it for me.
  8. I’m not either, had the chance to watch Thin Lizzy shortly before Phil died didn’t go just wasn’t enough of a fan.
  9. Pulled up to the first E10 pump I've seen - yesterday Guildford area...
  10. E10 isn’t available at pumps until 1st September
    Pump nozzles will have E10 signage rolling out up to September in a bid to be ready for the launch
  11. Morrison supermarket petrol has been E10 for a few years I believe. I was told by the dealers never to use Morrison’s petrol in my Ford
  12. No idea probably just usual noise
    On looking further there was an issue in 2010 wrong fuel delivered into tanks and more recently 2021 contamination into live tanks by a workman
    #34 Ducbird, Aug 21, 2021
  13. https://check-vehicle-compatibility-e10-petrol.service.gov.uk/manufacturer/Ducati
    The following models are approved for use with E10 petrol from the dates listed:
    Ducati Desmosedici 990 RR, Vehicles registered as from 18/05/2007
    Ducati Diavel 1198, Vehicles registered as from 27/10/2010
    Ducati Diavel 1198 ABS, Vehicles registered as from 27/10/2010
    Ducati Diavel 1198 Diavel Carbon, Vehicles registered as from 27/10/2010
    Ducati Diavel 1198 Diavel Carbon ABS, Vehicles registered as from 27/10/2010
    Ducati Hypermotard 1100, Vehicles registered as from 15/02/2007
    Ducati Hypermotard 1100 evo, Vehicles registered as from 02/07/2009
    Ducati Hypermotard 1100 evo SP, Vehicles registered as from 29/09/2009
    Ducati Hypermotard 1100 S, Vehicles registered as from 15/02/2007
    Ducati Hypermotard 1100 S+, Vehicles registered as from 02/07/2009
    Ducati Hypermotard 1100+, Vehicles registered as from 02/07/2009
    Ducati Hypermotard 796, Vehicles registered as from 02/07/2009
    Ducati Monster 1100, Vehicles registered as from 10/07/2008
    Ducati Monster 1100 ABS, Vehicles registered as from 14/10/2009
    Ducati Monster 1100 evo ABS
    Ducati Monster 1100 S, Vehicles registered as from 10/07/2008
    Ducati Monster 1100 S ABS, Vehicles registered as from 14/10/2009
    Ducati Monster 659
    Ducati Monster 659 ABS
    Ducati Monster 696, Vehicles registered as from 15/01/2008
    Ducati Monster 696 ABS, Vehicles registered as from 14/10/2009
    Ducati Monster 796, Vehicles registered as from 04/02/2010
    Ducati Monster 796 ABS, Vehicles registered as from 04/02/2010
    Ducati Multistrada 1200, Vehicles registered as from 04/12/2009
    Ducati Multistrada 1200 ABS , Vehicles registered as from 04/12/2009
    Ducati Multistrada 1200 S Pikes Peak Special Edition
    Ducati Multistrada 1200 S Sport , Vehicles registered as from 04/12/2009
    Ducati Multistrada 1200 S Touring, Vehicles registered as from 04/12/2009
    Ducati Streetfighter 1098, Vehicles registered as from 12/01/2009
    Ducati Streetfighter 1098 S, Vehicles registered as from 12/01/2009
    Ducati Superbike 1098 R Corse, Vehicles registered as from 30/10/2007
    Ducati Superbike 1198, Vehicles registered as from 03/09/2008
    Ducati Superbike 1198 SP, Vehicles registered as from 03/09/2008
    Ducati Superbike 848 evo, Vehicles registered as from 20/05/2010.
    Models not listed should continue to use E5 petrol. For further information contact your local Ducati dealer.
  14. This isn't exhaustive because most are E10 compatible and is even in the owners manual to say it is (my V2 does for example). I would still only use premium which I believe is staying as E5, but if worst comes to worst, check your owners manual (you can download electronically if out on the road) and if it's listed, you can use it.
  15. They’ve put a sticker on the tanks of bikes to tell you what they will take too.
  16. Yeah and that. Forgot about that, be a bit easier than checking an owner's manual :joy:
  17. There is a very interesting article about the effects of E10 from the Federation of Historic Vehicle Clubs : https://fbhvc.co.uk/fuels
    Although most of you will run modern fuel injected Ducatis it is still worth a read. The ethanol in the has a greater greater oxygen content, effective leaning the mixture. Bikes with modern injection and Lambda sensors will compensate to some extent but older bikes particularly those with carburetors will not. This could mead going up a size on the main jet and possibly lifting the needles by a notch. Whatever, fuel consumption will increase. The is of course the added problems of increased corrosion and detrimental affects on rubber and plastic components in the fuel system.
  18. They’ll carry e10 AFAIK even if like EssoSynery from certain stations are still lower.
