New exhaust / de-cat options?
Discussion in 'Multistrada' started by Neillfergie, May 29, 2013.
  1. Ok, so I managed to get a un-used de cat pipe from eBay at a price that was worth the risk.
    Chinese made but totally unbranded and the welding was actually quite neat, I was expecting it to look much worse.
    Fitting took about an hour of swearing and WD40 and getting the front header to separate but the fit was actually pretty spot on in the end. there's a mount for a center stand if I ever need to fit one.
    Refitted the original end can after getting the heat shield powder coated gloss black to freshen it up and the sound is mega, not too loud but deep and rich like a Ducati should be.
    Been running it now for about 6 weeks and without any further mods the bike runs fine, still lumpy at times and with some pops on the over-run but I quite like that...
  2. I'd love to see some photos of the powder coated heat shield on the original silencers.
  3. im toying with the idea of selling the quat d system of mine, carbon fibre with black cones
  4. I will get some pictures up this week. The whole look is very clean and un-molested but the sound is far from discreet! I like it and the cost was comically low compared to full systems etc
  5. Great, thanks. I'm thinking of going the same route as you, except with a Leo Vince decat as it has a small silencer in it which should reduce the volume a little. I am interested in seeing the powder coated original tail pipes though. Thanks.
  6. How does the cheapo decat from China deal with the valave cable?
  7. It doesn't is the short answer, You need to construct some sort of spring arrangement (like I tried) or purchase a exhaust valve override thingy off ebay for about £80... I did the latter
  8. How is it fuelling? Does it need or has it been mapped?
  9. Fueling is ok, no worse at low rpm than it was originally, actually feels slightly better through the mid-range with less of the hesitancy as you open the throttle...
    Pops and bangs on the overrun but I quite like that so I'm not going the bother with the remap.
    A remap would probably make better use of the free flowing pipe but I'm not too worried about gaining 2-3hp, there's plenty of power already, unless you found it too tricky at low speed or the popping annoyed you could live without it.
  10. Do you have a link for the exhaust valve faker?
  11. #32 Psy69, Aug 21, 2013
  12. #33 Nik the greek, Aug 21, 2013
  13. Put on a Leo vince carbon end can and decat pipe has better grunt and midrange is awesome no need to remap and it sounds great put baffle back in
  14. If I am looking for used Ducati and it has aftermarket cans on which aren't Termi's I just go to the next ad. Most buyers like originality.
  15. I'm thinking about selling my mivv decat and baffle, took it out as even baffled was way too loud for me. Without the baffle its plain offensive IMHO
  16. All my bikes Ive sold I have put the original can back on. Generally speaking the systems are worth more off the bike then on it.
  17. Looking at some of the videos on youtube, one shows the decat pipe and std end @116db, compared to around 90db std, and i think the termi was 109db !
  18. I reckon that chinky decat is worth a try. How easy to fit it?
