£1,500 - I got them from Kyle Racing in the US. He'll knock a few quid off. You just got to hope HMRC are kind to you on the way in....otherwise they'll be £2k
I was just looking at the US but was worried about what the charge might be coming to the UK. I take it you got let off lightly then?
I think it works out at quite a bit more than £2k, something like £2.3k when I ran it through on online duty calculator. If the sender is willing to state a lower value on the customs forms then you're ok, otherwise you're betting off getting them from here.
They are beautiful forks though...and Dan will set them up to your weight. They are a straight swap, only thing you need to do is experiment with the supplied spacers to get the ABS sensor the right distance from the ABS ring. 1.3mm to 1.9mm
Carbon rims are not exactly pretty just molded carbon,you cant beat a beautifully machined piece of alloy,carbon rims do look better on double swingarm bikes but look wrong on sssa bikes as the spokes are just to chunky.Cost has nothing to do with it at all its just personal preference.You pays your money and all that.
Check out the pictures of this BST and see description! BMW S1000RR BST Carbon Rear Wheel & Disc & ABS & Sprocket 2010-2016 | eBay
Good luck with that sale! I suppose at least he's been very honest but you'd be fckin crazy to ride on that
BST are obviously not worried about safety as they can tell from a photograph that its safe! Very glad BST don't supply Aerospace parts
