Nice But Dim . . .
Discussion in 'Supersport (1974-2007)' started by dickdastardley, Sep 18, 2014.
  1. well I seriously have to come up with a solution
    headlight was hardly illuminating the back of a car 20 odd feet away on way home from work
    almost side swiped by a car (again) probably thought I was a push bike
    has anybody checked the voltage at the headlight connectors to see if voltage loss is occurring
    possibly thinking bypassing the large wiring connector and seeing if its that
    there must be way around this because as it is its bloody dangerous
    think my old fizzy had a better light and think it was 6 volts :Arghh:
  2. It has been suggested elsewhere that the poor earth set up can be causing this the dim lights. Two thoughts spring to mind -
    1. Put in a separate earth for the head light
    2. Run power direct from the battery and through a relay to the bulb and put the head light switch across the relay.
    3. Or try one of these HeadLight H4 LED Bulb 120 LED White | eBay
  3. have looked at the led bulbs but not sure
    intend to put in extra earth
    relay could be a good idea ............bit like the set up for adding extra spotlights hmm
  4. Read somewhere that LED bulbs don't work well in projector lights like the 749/999 ones, if they are not specifically designed for LED bulbs.
    This is because the light source ends up being in the wrong place for the optics to focus the beam precisely.
    I don't know if this is the case or not with conventional reflector lights.
    I'm amazed though that a 2007 SS should have the same dim lights issue of my '96 square light SS.
    I did manage to improve that with aftermarket high quality/output bulbs but still not great...
  5. So what's a good after-market bulb for my 1999 900SS that won't fail an MOT and will at least give the standard light a boost?
  6. Look up
    [​IMG]Autobulbsdirect.co.uk
    Maximum Vision
    Add to compare
    H4 OSRAM Night Breaker Unlimited +110% Upgrade Xenon Headlight Bulbs (Pair)
    SKU: 64193NBU-HCB • [​IMG][​IMG][​IMG][​IMG][​IMG] 4.5 (28 Reviews)
    • Brand New Osram Night Breaker Unlimited
    • Up to 110% more light than standard halogen lamps for increased night vision
    • 35 metre longer light beam allowing hazards along the road ahead to be seen sooner
    • 20% whiter light to reduce eye strain and making night driving more comfortable.
    Product Details
    £18.45 (Inc. VAT)
    RRP: £29.99 (Save 38%)
    In Stock
    123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100
  7. Thanks very much for that Old rider, much appreciated.
  8. Change the headlamp relay. That made a big difference with the brightness of the lamps on my 749
  9. Thanks Duke, what's the relay and where can I find it? Ta.
  10. Probably good to do both.
    It wouldn't have occurred to me that the relay would cause extra resistance with age but if that's what you've found to be the case, it's a quick, cheap and easy fix.
    Did you use a particular brand (eg Bosch) or just generic??
  11. need on in a hurry so i got one from my local indie. e-bay sell them for £1.90/ea
  12. I can't be ar*ed to change bulbs etc on mine........the first time I used the SS in the dark, I was pleasantly surprised how good the headlight was despite the rubber seal missing (now fitted) which threw a lot of glare back at me.
    It's certainly a damn sight better than my Guzzi Le Mans and various Kawasaki headlights on previous bikes including the ZZR1100.
