Non Tool Tools
Discussion in 'Ducati General Discussion' started by Washhand, Feb 28, 2015.
  1. Straightened wire coat hanger for putting wires through. Espresso machine (copied from the works Ducati guys)
  2. An old penny from before the 90's when they were still copper, for locking gears if your loosening or tightening whatever's on the end of their shafts
  3. Magnet on a telescopic stalk for removing clutch plates.
    Found a really good one in Sainsburys the other day that just pulls the plates right out. Even works on alloy plates if they're sintered.
    Put the plates on the r/h footrest as they come out, then you can just put them back in in the order they came out with minimum fuss.
  4. To protect the garage floor and back wheel, I use an old Pizza box (L) when cleaning and lubing chains
  5. A piece of thin cable salvaged from an old garage door mechanism. Cleated loop at each end. Makes stretching springs to fit over a post (like side stand spring) dead easy :D
    Also works well as a garrote :)
  6. Therapist!
