899 Panigale 899 Mods???
Discussion in 'Panigale' started by Danxr46, Aug 29, 2020.
  1. Oh right. I’m over road to you then
  2. Yes it is for sure
    maybe one day a ride out if there a few in Lincolnshire
  3. I’m up for a ride Lincolnshire way. Not too far away from:upyeah:
  4. I’m close to Woodhall but work in Lincoln - or did before remote working became the new normal!
    I just answered the preload question in the other thread but I’ll repeat - fully out = anti-clockwise - 2 turns in (8 clicks) for stock road or 6 turns in (24 clicks) for performance. :upyeah:
    Fully recommend booking a novice only track day - far less likely to get fast people bumping down a group and a good intro to track riding.
    Great way to meet other novices too.
  5. You are only a little heavier than me and full track gear adds another 11kg - you are about right really for the weight range the stock suspension supports. Especially for road riding as the bike is a bit heavily sprung for lighter riders.
    You would have to really be pushing to need more than the stock forks. The suspension can be a little harsh for road riding though (especially on Lincolnshire’s roads.......) I have a Ktech DDS pro rear shock fitted and the ride and control is so plush I don’t notice bumps on track that upset other bikes - to the point that I’m not sure what mates are talking about when they discuss the circuit! So definitely a worthwhile upgrade.
    I swapped out the rear shock linkage for the 1199/1299 one and set it to flat rate - the progressive rate linkage that’s on the 899/959 as stock is designed to accommodate a greater weight range and the possibility of a pillion but it is a compromise so if you only plan on solo riding, and especially if you upgrade the shock I would consider it.
    I bleed the master cylinder after every track day as it only take seconds and keeps the lever nice and firm.
    I have just swapped to EBC gpfax pads and they are a big improvement on stock.
  6. what 29?
  7. Yes pal
  8. Seen another 899 today in white and another panigale at Italia Moto this lunchtime
