V4 Pikes Peak
Discussion in 'Multistrada' started by Steelboss, Oct 10, 2021.
  1. My god, someone actually rides with DTC & DWC set to 6 :astonished::joy:
  2. And with crazy high tyre pressures.
  3. I'm considering buying a PP. Never had a Ducati. I'm 5'9 tall and 70kg. Anyone here about that height and weight that rides a PP (or a V4S for that matter) ? How do you find the size of the bike? Not so much while moving, I'm more interested in slow speed, parking up or generally moving the bike around. I know a test ride is the only way to find out for myself but I doubt I'd be able to get a PP for a test ride. Would I notice much difference between riding a PP and a V4S from a size/weight point of view? Would a test ride on a V4S give me a good insight into a PP?
    TIA.
  4. I haven't tried Urban, but I'm assuming that's the standard settings
    Indeed, but it's showing PSI and I still can't find it post software update.
  5. I'm 5'10 & 69kg. But have a 33" inseam, so have no issues whatsoever with the height. I run the high seat in the high position most of the time. I test rode a V4S before getting the PP, as there weren't (and still aren't) demo bikes. I find the PP feels pretty much the same, size wise maybe a bit smaller due to the smaller screen, but the handling is much sharper IMO.
    #2006 Multirider75, Jul 31, 2023
  6. I saw a Multi with the lowered seat on Saturday, the fella can't have been much taller than you and didn't seem to have any problems.
  7. Howdy all. So, I’m 6000 km into my Pikes Peak and absolutely loving it. It does everything well. It’s comfortable, very fast and looks fantastic. However, and this isn’t the bikes fault, I’m struggling to find a satisfactory mounting solution for a Garmin XT2.
    I’ve mounted it with an Iconic mounting system with a touratech locking system. Now I do realise that this is a relatively heavy set up but it shakes and vibrates excessively to my mind.
    I saw a YouTube video of the Evotech set up. This is fastened to the bike through the 4 screen bolts.
    Has anyone used the EP Mount and can they comment on whether this may be a steadier solution than the iconic.
    I’m actually tempted not to use the Garmin at all and just rely on the in built Sygic Nav which I used in Romania and is perfect for point to point navigation.
  8. I’d check your Iconic mount is fitted properly, as mine doesn’t vibrate at all.
  9. I’ve got an evotech mount with a Garmin XT, and lock plate (not touratech) and it’s absolutely fine, made of decent thick alloy that users the 4 bolt holes as it’s mounting points so spreads the load a bit I think, only slight issue is the nav sometimes drops down on very bumpy roads on the amp bracket, just adjust it back up again and check the two side hand bolts and it’s fine again, no problem on smooth roads whatsoever
  10. Think the extra weight is causing you issues , take of the toura shackle and you may be surprised . I used a smaller lock that weighed next to nothing .The iconic mount is very good and also well made .
  11. Agreed. I use the Zumolock with the Iconic mount, it’s as solid as a rock.
  12. That’s my own feeling too. I’ll try it without the lock.
  13. I have used both the Evotech mount and the Iconic, the Iconic is better for me. The Evotech mount is heavy and very sturdy BUT when mounted on a V4S it upsets the airflow for the screen and definitely makes it noisier with some turbulence for me, you may find it OK. this is because it mounts between the screen and the plastic and interrupts the airflow through the screen slot IMO. There is no noise when the Iconic is mounted as it is a bit lower down. Personal opinion but to me it does look a bit agricultural as well, no idea why is such thick steel and so heavy.
    If you want the Evotech mount let me know.
  14. Question re suspension. I understand that the suspension settings (compression and rebound damping) alter depending on the bike mode selected. Is it also possible to tailor rebound and compression within a set mode? I.e if you were in urban can you then add additional compression damping if you wish?
  15. Anyone put a few miles on their bike, 10K plus? How has the reliability been?
  16. not that much. 6k+ so far - and so far so good :upyeah:
  17. 12500 on mine.
    All good. :upyeah:
  18. Yes look in the menus. I presume it the same as the v4S where you can vary front and rear from soft thru to hard.
    Not possible to alter compression and rebound separately though.
  19. When I get chance to see one in the flesh I'll have a look thanks.
