V4 Pikes Peak
Discussion in 'Multistrada' started by Steelboss, Oct 10, 2021.
    Saw this cover on an RS. Don’t think I’ve ever seen it before, would it fit the PP? Certainly looks like it will.
  2. The belly pan? Looks like it’ll get chipped to hell, but does look very nice.
  3. Apologies, meant the alternator cover.
  4. Had one on my SF V4S … if that’s of any help
  5. Ah ok, I like the belly pan now I’ve seen it!
  6. Tart :upyeah:
  7. I've got the Gilles footrests and levers too. No, you don't need adapters for the footrests. Take the pin out holding the original one in place and slide the new peg in. Straight swap. Hardest part was getting the split pin out.
    The original PP pegs are 10mm further up and 10mm further back so you loose that.
  8. And it breaks your heart every time you grind them on the tarmac......
  9. Finally ordered one of these tails today, looking forward to fitting it.
  10. 20240619_084123.jpg 20240619_093531.jpg 20240619_094305.jpg 20240619_115427.jpg 20240619_130446.jpg 20240619_132452.jpg Halfway through a trip round the Dolomites, Slovenia and the rest of the Alps. This bike is awesome
    • Like Like x 13
  11. Some great pictures.
  12. The big bag is a Ventura system. I've used it on all my bikes for the last 15 years or so. I'm pleased with it. The smaller one behind it is just a Givi tank bag. I bought a Givi "tail mount" plate and drilled it so I can fit both at the same time. I normally just have the Givi bag on for essentials. Both bags mount into the 4 existing holes in the standard grab rails.
  13. The Ventura looks good, but it looks like you're sat quite far forward? How's that for comfort?
  14. Riding normally its fine. There's plenty of room for me to move backwards and forwards. If I activity lean back I can rest against the bag but I wouldn't be able to ride like that for long . I'm 5'9 so for someone over 6ft it nay be an issue. But it depends on the length of your arms I guess. It's perfect for me :upyeah:
  15. I can't see any reason why you can't mount these brackets the other way round which would move the whole thing back by 5cm 20240620_121418.jpg
  16. Apologies if my filthy bike has just trigger anyone's OCD :p
