V4 Pikes Peak
Discussion in 'Multistrada' started by Steelboss, Oct 10, 2021.
  1. I don’t, but will use that code in future, ta!
  2. Some winter mods:
    Bars, riser and yokes now black
    Brake and gear lever
    Downpipes cerakoted and Evotech engine guards
    And at great mechanical expense, oil cap!
    I’ve also had the side stand, centre stand and bellypan powder coated.
  3. Looks good :upyeah: What colour Cerakote are the downpipes, and can I ask who did them for you?
  4. They are black, look a bit grey in the pictures.
    A pretty much spot on match with the belly pan.
    Done by a company called Raw Coatings in York. Cost £120.
  5. Great - many thanks. They are not too far away from me. I'll drop them a line on Monday. Satin or Matt black?
  6. Good question, I think they are the same.
  7. More Carbon bling
  8. [​IMG]
  9. They look great, but make sure you get them protected, as they’re right in the firing line for stone chips, and will look awful after a few rides if you don’t. The ones on my GS suffered.
  10. Were they cerakoted?
  11. Yep. Sorry.
  12. Bugger!
    Any suggestions? Does the standard V4 fender extender fit the PP?
  13. No it doesn't, pyramid will have the pp version out in about a weeks time.
  14. Probably more likely that a 1200/1260 one will fit than a V4S. The front mudguards on the V4 look quite a lot different.
  15. 1200/1260 will not fit, pyramid sent me the mould for the pp after they're first batch did not fit, it will fit now and has gone to production, i also have a 1200 as well and its totally different to the pp.
    • Useful Useful x 2
  16. Fitted the upper guard today. Bloody fiddly to get it mounted without wrecking it, but it’s on now.
  17. Did you buy the lower guard too?
    If you haven’t fitted it yet, it’s easier with the upper part removed. Ask me how I know…
    It's only three screws.
  18. I did. Now you tell me!
  19. If anyone sees this on the website before the rest of us, post a heads up.
    Thanks.
