V4 Pikes Peak
Discussion in 'Multistrada' started by Steelboss, Oct 10, 2021.
  1. Tarts bike though, tbf :joy:
    Was the horn easy to fit?
    #1881 Multirider75, Mar 4, 2023
  2. Dead easy, I could probably have got away without bending the bracket but the plastic was sat hard up against the horn.
    A slight mod satisfied my OCD!
    The horn mounts facing the nearside. 20 minute job.
  3. How do you get to it?
  4. 4 x 4mm(?) screws hold the black plastic cover under the nose cowl.
    10mm on the back of the horn and 12mm holds the bracket on the bike.
    • Useful Useful x 2
  5. Don’t do it, it will end in tears when you break something o_O
  6. Did you sort it?
  7. Well the PP V4 is a revelation in many ways, not least it has a working back brake! A real novelty for a MTS… no neutral to be found though :-/
  8. Gets better after the first service.
  9. Not yet. Was going to do it when I finished work, but ended up putting the new Weber together instead! Will do it one night in the week.
  10. Carb, air rifle or bbq?!
  11. Bbq! Bought a new Smokey Mountain in the Black Friday sales.
  12. The PP Facebook page has a post about the Evotech tail tidy. I’m not a member so don’t think a link would work.
    In a nutshell the cover is a water trap. So drill two holes in the rear, there’s two raised domes that appear to be the right place. Also, the cover fits inside the rear radar. I checked and I’d fitted the cover outside.
    Now on, I think, correctly.
    #1893 gc6269, May 3, 2023
  13. Today: Leeds Ring Road around 2:30pm.
    Only the third one I've seen on the road, anyone on here?
  14. Wasn't me! :D
  15. nor me :cool:
  16. I should rule myself out too, I was in the car.
  17. If you head over the Pennines to Manchester you’ll see hundreds. Ten a penny over there. Seriously.
  18. Disconnected the battery, tightened everything up and this came on, DES.
    Been out for a ride and seems ok, but the light hasn’t gone out.
    Any ideas?
    https://i.imgur.com/IGy0uN2.jpg
    #1899 gc6269, May 20, 2023
  19. I think it's the calibration for the electronic suspension.
    I had a flat and the RAC guy started my v4s up on the center stand, and it wanted to re-calibrate the suspension afterwards as it got confused!
    (but the std multi v4 has different suspension)
