1299 Project 1704 - 1299s Build Project By Topolino
Discussion in 'Panigale' started by Topolino, Dec 1, 2016.
  1. So how did this tidy up finish?
    A great bike to live with?
  2. Any updates to this?
  3. No he won't talk!
  4. Congratulations to this awesome job and the perfection you're putting into the bike. Could you please tell me which type of Cerakote and also which "colour" was used on your monocoque frame? Is there any specific code or number that I could refer to when sending the items to Wesley & Andy?
    Thanks a lot and many greetings from Germany.
  5. Shame we didn’t hear how this one was as a daily rider, had some nice bits. Or did I miss a review of it somewhere?
  6. Rod has been working a lot completing a course abroad which may explain the lack of updates.
  7. As Ian says, been a bit hectic workwise to update the thread, however I will try and post up some pics this weekend. Things have moved on in the year or so since I bought this bike and completed it. As with all my projects, most of the satisfaction comes in the building and planning phase and yes it is a great bike to ride but having now ridden the V4, the plan is to return this one to stock (again!) and move on to the newer technology. I will have a stack of exceptionally desireable parts that will not fit on the new bike so keep your eyes peeled on my ecommerce site for details. As promised pics will follow later of the bike as it currently stands.
  8. Are you his Dad?
    By the way, happy Fathers Day to all the Australian Dads.
  9. Here's a few pics of the bike completed, back in November 2017. (I have a box full of brand new CDT FullSix complete carbon bodywork for the whole bike as well, plus a new Ventureshield kit and a double bubble PUIG clear screen, that were never fitted, which was the original intention but life gets in the way of a lot of grand ideas sometimes). There is a heap of stuff on this bike (too numerous to mention here) that will be up for sale soon. Details to follow in a month or so. Unless of course I decide to sell it as is, if there are interested parties in which case I will publish a comprehensive list of all the mods and parts (which will take some time) and what I think to be a fair price given the spec.
    20171108_154751.jpg 20171108_154756.jpg 20171108_154815.jpg 20171108_154952.jpg 20171108_154925.jpg 20171108_155045.jpg 20171108_155020.jpg 20171108_154917.jpg 20171108_154852.jpg 20171108_154832.jpg 20171108_154958.jpg
  10. Nice bike that :upyeah:
  11. OK so I'll be starting the strip down to return this bike to stock soon, in preparation for its part exchange for the new V4S. Parts taken off will be available as normal online, through my retail store. These will include a multitude of both CDT Fullsix and Lieb Speed gloss carbon parts, RapidBike Pro fuelling controller and custom fitting kit, Samco hose kit, CNC Racing billet aluminium parts, including RPS400 rearsets, Oberon turns signals and bar end mirrors (including Motowheels adaptors), full Akrapovic race exhaust system, Bursi Evolution ride height link, various Rizoma accessories and more besides. New CDT Fullsix carbon bodywork in matte, will be online later today, plus a new PUIG double bubble screen and new complete Ventureshield kit.
  12. Topolino, how do I find your retail store? Cheers
  13. It's in my signature below Jat.
  14. OK, a lot of people have been asking me for a full spec list on the bike, as I might be persuaded to part with it "as is" for the right price, so here goes. If I can't find a willing buyer who wants to ride this bike away, then this will read as a shopping list of parts that will eventually populate my online store for sale.
    Stainless Steel Fasteners
    Pro Bolts - Polished Stainless Steel Fasteners (Bolts, Nuts, Washers)
    8 x Inlet Manifold Retaining Bolts
    8 x Throttle Body To Manifold Retaining Bolts
    1 x Blow By Union Mounting Bolt
    2 x Fuel Tank Front Mounting Bolts
    3 x Water Distributor Mounting Bolts
    3 x Front Shock Absorber Mounting Plate Bolts
    6 x Lower Yoke Bolts
    3 x Top Yoke Bolts
    4 x Clutch/Front Brake Master Cylinder Clamp Bolts
    2 x Master Cylinder Bleed Nipples
    2 x Clutch Line Banjo Bolts
    2 x Clutch/ Front Brake OEM Reservoir Support Bracket Blanking Bolts
    3 x Clutch Slave Cylinder Mounting Bolts
    1 x Horn Retaining Bolt
    12 x Front Brake Disc Mounting Bolts
    3 x Oil Cooler Mounting Bolts
    2 x Radiator Mounting Bolts
    2 x Radiator Shroud Mounting Bolts
    4 x Front Caliper Mounting Bolts
    2 x Front Caliper Bleed Nipples
    3 x Front Brake Line Banjo Bolts
    1 x Rear Shock Absorber Mounting Bolt
    1 x Rear Suspension Link Rod Front Mounting Bolt
    1 x Rear Upper Chain Guard Bolt
    4 x Chain Guide Bolts
    4 x Chain Guide Collars
    3 x Front Sprocket Cover Bolts
    2 x Start Relay/Solenoid Bolts
    3 x Battery Box Mounting Bolts
    6 x Handlebar Clamp Bolts
    2 x Ignition Switch Mounting Plate Bolts
    2 x Steering Damper Mounting Bolts
    6 x Electrical Box Mounting Bolts
    1 x Battery Clamp Bolt
    2 x Front Subframe Mounting Bolts
    3 x Instrument Panel Mounting Nuts
    1 x ECU Clamp Bolt
    1 x Rear Brake Reservoir Mounting Bolt
    2 x Rear Brake Caliper Mounting Bolts
    2 x Rear Brake Caliper Pinch Bolts
    1 x Rear Brake Caliper Bleed Nipple
    2 x Rear Brake Line Banjo Bolts
    1 x Rear Wheel Speed/ABS Sensor Mounting Bolt
    1 x Front Wheel Speed/ABS Sensor Mounting Bolt
    4 x Front Axle Pinch Bolts
    2 x Front Nose Fairing Mounting Bolts
    1 x Gear Change Actuating Arm Bolt
    1 x DQS Front Mounting Bolt
    4 x Number Plate Assembly Mounting Bolts
    Titanium Fasteners
    6 x Perspex Screen Mounting Bolts
    2 x Rear Swing Arm Pinch Bolts
    1 x Front Axle Nut
    2 x Rear Axle Nuts
    6 x LH/RH Switch Gear Mounting Bolts
    3 x Special Mounting Bolts (Brake Line Cover & ABS Cover Bolts)
    6 x Rear Sprocket Bolts
    Billet Aluminium Parts
    4 x Red Anodised Desmoworld Frame Plugs (2 on rear subframe, 2 on swing arm pivot)
    1 x CNC Racing Black Anodised Top Yoke
    1 x CNC Racing Black Anodised Steering Stem Nut
    6 x CNC Racing Red Anodised Bleed Nipple Dust Cover Caps
    1 x CNC Racing Red Anodised Coolant Filler Cap
    1 x Red Anodised Oberon Clutch Slave Cylinder
    1 x Ducati Performance Fuel Filler Cap (Anodised Black)
    2 x Black Anodised Rizoma Fluid Reservoirs (Front Brake & Clutch)
    1 x CNC Racing Red Anodised Rear Brake Reservoir Cap
    Rizoma Span Adjustable Front Brake Lever
    Rizoma Span Adjustable Clutch Lever
    1 x CNC Racing Red Anodised Oil Filler Cap
    1 X RPS 400 CNC Racing Pair Of Rear Sets (all associated bolts changed for polished Pro Bolt fasteners)
    2 x Oberon Bar End Mirrors
    2 x Motowheels Bar End Adaptors
    1 x CNC Black Anodised Sprocket Carrier
    Pair Of OZ Racing Black Anodised “GASS RA” 6 Spoke Wheels
    1 x CNC Racing Clutch Cover Black Anodised Crash Protector
    1 x CNC Racing Black Anodised Generator Cover Crash Protector
    Carbon Fibre Parts (All GLOSS finish)
    CDT Fullsix:
    Rear Number Plate Hangar (includes custom made plate to conceal wiring)
    Rear Seat Cowl
    LH Cylinder Head Heat Shield (+ Access Inlay Panel)
    RH Cylinder Head Heat Shield
    Rear Brake Line Cover (Fairlead Cover)
    Swing Arm Brake Line Cover
    Rear Sprocket Cover
    LH Electrical Box
    RH Electrical Box
    Battery Cover
    ABS Cover
    Lower Yoke Splash Guard
    Side Stand
    Instrument Cover
    Lieb Speed
    Fuel Tank Protector Pad
    Ignition Switch Cover
    Shock Absorber Guard
    Subframe Covers
    Rear Hugger
    Upper Rear Chain Guard
    Shark Fin Guard
    Swing Arm Guard
    Performance Accessories
    Full Akrapovic Titanium Exhaust System (all associated mounting bolts changed for Pro Bolt polished stainless steel fasteners)
    Sprint Hi Flow Air Filter
    Samco Silicone Hose Kit (+ Stainless Steel Jubilee Clips)
    Rapid Bike Pro Fuelling Module, complete with custom made loom mounting brackets
    Bursi Evolution Adjustable Suspension Link
    SuperSprox Black Anodised Rear Aluminium/Steel Rear Sprocket (41 teeth)
    Brembo Goldline 330mm Fully Floating Front Discs
    DID Gold Chain (102 Links)
    Electrical & Other Parts
    Oberon Bar End Turn Signals
    Bike Trac Tracker Unit (dealer installed)
    Optimate Lead (hard wired) plus charger
    Pro Grip 717 Handlebar Grips
    Modifications
    Main Monocoque Airbox/Frame Cerakoted - Colour Matched To Magnesium Engine Castings & Front Subframe
    Rear Swing Arm – Cerakoted – Colour Matched As Above
    Footrest Hangar Castings, Rear Suspension Rocker Link Plates, Front Shock Absorber Mounting Plate, Handlebar Clamps – Cerakoted Satin Black
    Handlebar Tubes – Hard Anodised Black
    Radiators – Ceramic Coated Black by CamCoat (fitted with custom aluminium grilles front and rear, mounted with snap cap invisible fittings, grilles powdercoated black)
    Front Carbon Mudguard – Clear Coated With Airbrushed Corse Logo On Leading Edge, Venture Shield Fitted
    Road Angels - Instrument Panel Screen Protector
    Additional Items – Included
    All OEM plastic panels and bodywork removed
    All OEM components removed
    OEM Exhaust System
    Warranty/Service Booklet
    Datatag Registration Card
    Bike Trac installation Certificate
    Owner Manual
    2 x Ignition Keys
    Leather Ducati Documents Binder
    Additional Accessories
    NEW MATTE Carbon Fibre Parts
    CDT Fullsix Headlight Fairing
    CDT RHS Upper Fairing
    CDT LHS Upper Fairing
    CDT LHS Seat Panel
    CDT RHS Seat Panel
    CDT LHS Seat Spoiler Panel
    CDT RHS Seat Spoiler Panel
    SECOND HAND Carbon Fibre Parts
    CDT LHS Lower Fairing (Professionally painted and PPF Film fitted)
    CDT RHS Lower Fairing (Professionally painted and PPF Film fitted)
    Miscellaneous
    Ducati Performance Indoor Cloth Cover
    PUIG Double Bubble Perspex Screen (Brand New)
    XPEL PPF Paint Protection Film – Full Kit For 1299
    Thats most of it. I may have forgotten a few of the bolts here and there but save to say, most of them excpet those on the engine itself or where special shouldered bolts were required, have been changed out.
    #95 Topolino, Sep 6, 2018
  15. Yes when I can, in between work commitments and whenever the weather permits Martin.
  16. I have edited the list above (initially items in bold red will be for sale)
  17. Can I have first dibs on the tank protector pad? :)
    I like that one.
  18. OK Bootsam. I'll let you know once I start stripping the parts off......Topo
  19. Lol at 'Topo' given my Pipkin avatar...
