QD Exhaust
Discussion in 'Multistrada' started by Tripletrouble, Jun 7, 2012.
  1. Jesus. Must check the box, didn't realise there were even more DB killers. Take 'em all out.
  2. Yes, those are the ones that are the 'cat' .....you know how it says in the description "Comes with cat replacement. EU homologated" ....I.e. to meet the noise tests... Those. Like little flat plates with holes in. Don't fit them. ;-)
  3. I cant bloody wait to here these, I'm getting a semi, back later !!!!!!!!!!
  4. Too fookin loud!!!
    Happy with the baffles in, not much quieter than a MiVV but just about bearable.
  5. Still no response from QD by the way.
  6. I missed your post on here, how I don't know but I did hence no respomse from me.
    I appreciated the response you sent and didn't feel the need to reply as your explaination was very thorough, thanks for that. Not to worry, no harm done and a decent price to boot!
    Now if I can just get an answer from the Italians...
  7. Once again no answer.
    Tells me all I need to know about what they think of their customers.
  8. Why don't you call them? I agree, they should reply to you quickly, but you have no idea the size of the company, and who deals with the emails. There could be a simple explanation.
    If it were me, I'd first talk to Joe at Spareshack....Joe, are you reading? ....then, I'd give QD a call in Italy. Seriously, you can get numbers to call internationally from your mobile for "pence per minute"... Look at the link I posted.
    And yes, I agree you shouldn't have to but you have a concern, so to set your own mind at ease, and/or find a solution give them a call. Manuel De Liso (owner) speaks English, so you should be fine.
    I sincerely hope this helps, and you get the answers you need.
  9. I am calling them in the next few minutes.
  10. The number on their website doesn't work.
    I've asked Joe to see if he has an alternative number.
  11. 0039 161 805666
    Is that what you dialled?
  12. That's the number I used, yes. I just get "This number has not been recognised".
  13. Try this.... 0039 0161 805666 ....a quick check shows that you don't "drop the zero"
  14. Didn't realise about not dropping the 0.
  15. No, nor me, but I looked up calling UK (or anywhere) "to" Italy, and it seems that is the case....you need the zero... Ah well, hopefully that will work now.... :upyeah:
  16. That was a waste of time. Manuel simply said "either cut the bracket or bend it until it works, it's the tolerance of the fitting of the Ducati stand that has caused the problem, we've never had that before."
    When asked why he didn't reply to me after admitting he'd read my e-mails, his answer was "sometimes we don't reply, sometimes we do"
    Appalling.
  17. Well he is Italian....so it's no big deal. I know it is to you, but that is cultural differences for you..... Anyway, so your choices are:
    1. Cut it or bend it til it works
    2. Leave the centre stand off
    3. Talk to Joe, and potentially return the exhaust as not fit for purpose.....
  18. Yep, that's about it. Being Italian isn't an excuse though is it?
    I will make it work, photo the process as a guide for others and put people off buying their products wherever I can.
