Quality Tyre Pressure Gauge Recommendations Needed
Discussion in 'Tyres' started by TBay, Feb 19, 2025.
  1. put more in than you need and then the release valve to work down to the target pressure plus a squidge extra
  2. JACO ELITE PRO available from Amazon. It's dead accurate and will outlast you!
    There's many versions, check them out. Not expensive either.
  3. Never trust their reading, the pressures vary considerably. Good piece of kit though, but use a trusted gauge for actual readings.
    #23 James Garnor, Feb 24, 2025 at 2:11 PM
  4. If you can get one, this
    Oasser 20V Tyre Inflator Air Compressor Cordless Car Tyre Pump with Rechargeable Li-ion Battery, LCD Digital Pressure Gauge LED Lights USB Cable for Car Bicycle Tyres and Other Inflatables 120PSI P2S
    Amazon are current out, but they may be available elsewhere. Used to double check it with a hand gauge afterwards, now given up as there was never any difference.
  5. Positively modern compared to this
    http://www.alembic.com/
