Questions for Ducati
Discussion in 'Ducati General Discussion' started by JerryXt, Dec 7, 2012.
  1. Just ask why they persist in using belts instead of gears for cam drive when it is so bl**dy obvious that the idiosyncrasies of belt tensioning and potential belt failure can cause so much damage......weakest design point of a Ducati engine, I reckon....and in my mind it can only be a cost cutting excercise.
    AL.
  2. Do they have a delivery date for the centre stand I ordered for my GT1000 back in 2009?
  3. Should I fake my orgasums?
  4. You might as well...your missus does! :wink:
  5. Surely the Panigale has gear-driven cams? Probably the beginning of the belt phase out.
  6. bovvered? :)
  7. will there be a 1199 RR limited series?
    will they introduce an ohlins active suspension on the pani?
  8. I thought it was chain driven cams?
  9. From the Ducati website:
    The need to control the enlarged valves with the extremely precise Desmodromic system prompted engineers to replace the original belt transmission, mounted on the first Ducati Pantah in 1979, with a configuration mixing both chain and gears. As a result, the chain timing allows an efficient transmission of the motion between crankshaft and camshaft transmission and thanks to the automatic tensioning adjustment, ensures constant reliability and a reduction in routine maintenance costs."
    I have no idea how the chain/cam combination works, or why it isn't one or the other .
  10. What is the sequence after flashing amber?
  11. is that a bit of corporate bullshoite..........the gears have the chain wrapped around them......
  12. found this...
    does seem to be both gears and chain!
  13. Ah-hah! Still got a camchain then! Marvellous.
    I originally got my first Pantah because it didn't have a camchain. I got traumatised by Honda camchain tensioners that didn't work. Seeing as Ducati probably haven't made a camchain tensioner in living memory, what makes you think they got it right first time? Will the dry clutch rattle be replaced by the worn camchain rattle on the Panigale?
    We'll find out soon.
    They had made much of it being gear driven cams, but this is evidently rubbish.
    Be afraid. Be very afraid.
  14. Did they ever make a 749RS?
  15. As per Suzuki TL1000's
    Desription,
    The TLS motor featured a 90° V-twin for perfect primary balance and had hybrid chain/gear driven cams. A traditional cam chain turned a gear that in turn rotated the cams. This hybrid design eased maintenance immensely and gave the motor additional aural character because of the gear whine.
  16. im all for oral character.......i think thats what it said!
  17. Bye :upyeah:
  18. Not with me, she doesn't:wink:
  19. Hey guys. There's nothing more unsavoury on a motorbike forum than blokes talking about motorbikes. And even worse when the talk is about bits of motorbikes. No-ones' interested.
  20. What will Santa bring me for Xmas?
