1199 Quick Shifter Problem
Discussion in 'Panigale' started by PCRR, Nov 15, 2016.
  1. The manual doesn't say you can only use at full throttle I would suspect, so even if they could they couldn't discard a warranty issue as mis-use :)
    Very few use the as they are meant to be: on what ride do you get full throttle on the road these days? ;)
  2. That's very true. I'd just assumed it was in the small print somewhere
  3. Every single ride rrrrrraaaaaaaaaaaaaaa! (and a skid and a wheelie :D )
  4. Mine works (up and down) at most revs seamlessly. The only time it seems to have a hiccup is if you forget what you're doing and come off throttle on an up shift (which is understandable!).
  5. do you skid before or after the wheelie? If you turn off the electronics, its more likely the latter.....
  6. Good question. Usually I like to do a skidding wheelie. Usually it doesn't go as planned.
  7. New quick shifter fitted today by dealer. It's great!
  8. excellent, but mine is more great! :)
