749 Quiet Clutch Mod Question...?
Discussion in '749 / 999' started by xivlia, Mar 11, 2015.
  1. By dished plate I mean the convex plates with the dot marking on one side, I've never found it makes any difference which way they are, which order they are in or even if they are in there at all, just go friction/plain/friction etc. and use different thickness plain plates (if required) to make up the overall pack thickness.
    The only thing I can see is that a convex plate makes less contact with the friction plates that it sits between and that must mean less grip and more uneven wear, it's got to be better if the plates are flat.
    Neither of my bikes have convex plates in them and both clutches work perfectly, no slip or grab and despite my 916 having 2mm of play between basket and plate tangs which makes it rather noisy it still works fine.
  2. my pack all together is 40mm thick, is that okay?
    i have just rearranged it according to the manual, and now gonna put them back in.
  3. Think it should be 38mm.
    Have you put it back to pre-quiet mod?
  4. I aim for no more than 38mm, I have aftermarket slave cylinders (that reduce clutch pull) and find that if the pack is over 38mm then finding neutral can be tricky. I try to set mine at 37.something
  5. Yes, get it as close to 38mm as you can.
    If you are only doing the mod, one plate should not really affect the stack height unless you are replacing the friction plates with new thicker ones. This is because the first friction plate sits below where the first plate would be if it were a plain one, so I recommend making the stack height 38mm without the first friction plate. Leave out one of the adjacent pair of plain plates if you need to lose some stack height.
    If you want to orientate your so called dished plates theoretically correctly, they are the 1.5 mm ones and I only had one.
    The punch mark that shows you which side to place outwards is between the cut out notch and the inner teeth, it is pretty small.
    I say stick with the quiet mod, the plates and basket will last much longer and I defy anyone to cite any instance where any bearings have failed. Also, the engine doesn't sound as though it's beating itself to bits, which it is... Well, the clutch is.
    Put a friction plate in first, followed by a plain and just keep alternating, if you're a purist alternate the plain plate small cutouts opposite each other for balance and finish with the pressure plate. This should be orientated with the triangular arrow next to the post with the slot in it as in the pic higher up the thread.
    Make sure the pressure plate is located properly on the teeth as you tighten the springs.
    Check it for action and then check for drag at idle before you put the cover and fairing on.
    The clutch is not dragging if you can engage neutral at idle.
    Slip is the opposite of drag. Drag is what you have experienced and slip is when the engine accelerates but the bike doesn't.
    Best way to get the plates out is with a magnet on a stalk as available in Tesco and hang them on the foot peg as they come out.
    #25 Old rider, Mar 12, 2015
  6. Thank you for that information, however...i had to revert to "pre-quiet" mode.. i noticed that the OLDER friction plates were thicker, than the NEWER ones... so when i replaced ONE of the plain plate with one OLD friction plate, it increased the total stack size by 1-2mm.
    i dont know if thats over the tolerance, but being like that it added up to 40-41mm.
    now im just using the original setup.
    2x plain, 1x friction, 1x plain, 1x friction, 1x plain, 1x friction etc etc..
    as opposed to quiet mode..
    1x OLD friction, 1x plain, 1x friction, 1x plain... etc etc.
    with the quiet mode, even though i had one plain as spare... it was still stacked up too much, the older frictions are massive in comparison to the newer ones... they are 3mm EXCLUDING the friction material... i just measured the top notch... whereas the new ones notch is 2.5mm....
    if its any help, this is what i had bought..
    DUCATI 748/749/916/996/998/999/ST2/3/4 | eBay
  7. using the original set, "non quiet mode" is working fine.
    i just need to find a way to get the quiet to work.. maybe i need one old friction plate, but a thinner one..
    any one wanna donate? :p
  8. At least the MOT is back on.
  9. Seems odd to me.
    If the old plates were so thick, why did they not add up to way more than the stack height you got with just one extra old one that should be sitting below the first plain plate and barely lifting it.
    The quiet clutch mod relies on the first friction plate sitting down into the curves at the bottom of the basket slots. These are there as part of the machining process and not all aftermarket baskets have them if the slots are machined differently, so I wonder if your basket has these curves at the bottom of the slots?
    The friction plate would not normally sit so low because the plain plate slots are square at the bottom and that square bottom is higher than the bottom of the curve. Some people even manage to fit two friction plates in first!
    If it helps, I have some spare (thin) friction plates
  10. i did check the basket, and the curves are there for sure. i just dont know, i could only come up with that explanation.
    i mean, it does sound odd like you said, why didn the original plates become too thick initially..
    thats something i couldnt answer, but i can guarantee these new ones are thinner by at least 0.5mm
    if i could have one of your old thin friction plates it would be much appreciated! :D
  11. i.e. how it should be...........:upyeah:
    could always smear a load of grease over it, i hear that help with the "quiet mode"...:rolleyes:
  12. To clarify for the op, some people have tried smearing their friction plates with white lithium grease and then removing the excess. The idea is that it helps make the clutch smoother and less grabby. Some say you should heat the plates afterwards, some say it's not necessary.
    (I think) all those who have tried the lithium say it does work but you may get some clutch slip at first.
    There was a guy on here recently who had bought a 749R with a slipper clutch that was seriously grabby, the lithium grease thing worked for him.
    1. [​IMG]
      Simon PeckMember
      Did the lithium grease trick and its transformed the clutch issue. silky smooth. Id recommend trying it to anyone who has a grabby clutch
      #141
      Simon Peck, Feb 28, 2015
      Report
      + Quote Reply
    It has nothing to do with the quiet clutch mod other than being something that some people have done to their clutch.
    #34 Old rider, Mar 13, 2015
  13. You're welcome to a plate but I still really don't understand why it would be necessary.
    If your old friction plates were so thick and you had no drag with a full set, why would adding one below a set of thinner plates add up to a higher stack and cause drag?
    Are you sure you have the correct number of friction plates, it should be seven I think - eight total with the extra one.
    Having a thicker plate as your first one should be an advantage as it will have a larger bearing surface on the basket slots. if necessary, you could always remove the friction material and end up with a plain friction plate as your first plate.
    There's a guy in France who produces thick aluminium plain friction plates especially for this purpose.
    #35 Old rider, Mar 13, 2015
  14. nope, I've just checked the ducati workshop manual.........couldnt find anywhere in there saying put grease on your clutch plates....
  15. That's very helpful.
    Thank you. :)
  16. well the old plates were glazed and had no friction material left on them. and it was still 3mm thick, these new ones are 2.5mm thick at the notch, if i take the friction material into account, it would be thicker as the material is raised in both ends.
    maybe thats why? i dont know :\
    ALSO!... i noticed an annoying problem today..when the bike gets really hot, the clutch starts to drag... and i can smell burning ceramic.. and can see smoke coming out of the clutch area.. is that supposed to happen with new clutch friction plates?
  17. Looks like your stack height may still be too high OR your clutch needs bleeding.
    Lever span adjustment may affect it too.
  18. that doenst explain how the clutch is smoking and smelling of burning..
    why would having air inside the loop cause it to smoke and smell even on idle?
    as for the height, ill need to check it again.
    and the lever is an aftermarket lever and the setting is set to 6 on the lever dial which is the widest.
