Random Picture Thread Vers.4
Tags:
    @Pete1950 Here is a replica of that very bike. I spotted it at Monthlery some years ago.
    #3101 Borgo Panigale, Feb 20, 2025
  3. Billy Bragg in his wilder youth before becoming the saviour of social change & left wing political causes :thinkingface:
  4. That looks like a modern 650 Royal Enfield Interceptor.
  5. I have one of these in my car and it's a bugger to work on....
    • WTF WTF x 4
  7. Three members of crew at work on the starboard engine gantry of a Royal Navy Air Service North Sea type non-rigid airship during an anti-submarine patrol off the British coast, 1918.
  9. Best place for it! A hedge !
  10. What the hell is it? Looks like the mother and father of a mechanics nightmare!
  11. BMW twin turbo v8. After realising bmw main dealer mechanics are baffled by anything more than an oil change i decided I can do a better job.
    This last year I have diagnosed and repaired canbus problems, failed charge air coolant pump, failing air suspension, and high pressure fuel system problems. None of which the stealers could deal with.
    #3111 ducv2, Feb 22, 2025
    • WTF WTF x 2
  13. Free replacement if the first one runs away is a good deal though.
    • Funny Funny x 5
  14. Aarrggghh!! Noooo!!
    • Funny Funny x 5
  15. Think most dealers just want to plug in a computer and charge you for the honour and not even fix the problem, they're just getting lazier.
    Where i'm working they had to send in a sprinter chassis cab as it was throwing a fault on PDI, 3 days and £1500 later they misdiagnosed the issue and that was without fixing a pinched wire. It took a freelance auto electrician 3 hours to find the fault, with just a multi tester.
  16. Yep, tech only seem to be able, or perhaps are only allowed, to follow a proscribed flow chart when debugging a fault. Replace wire A, is fault still there, replace connector B, still there, replace part C etc etc.
    I had similar with an ABS fault light that turned out just to be a build up of brake dust on one of the wheel's speed sensor.
