Hi guys, I’ve fitted the rapidbike up/down shifter to my 899 and I seem to have a slight problem in that when accelerating in 1st at around 6k it wants to cut throttle like it’s gonna change gear? Someone advised me to set preload to 70 but that hasn’t helped. Just wondering as you guys are saying set to 35?
Had the same problem with my 1199. Nothing helped. Then they send me from rapidbike 8 special blipper sensor settings that you upload your blipper and it is less sensitive to Ducati V2 vibrations. Dont know if this will also work on the 899 bit you can try. PM me your mail and i can send you the files cheers
