It's in the smaller photo just bit of 3mm plate shaped same as screen adjustment lever then made into a angled plate to mount Tom Tom to mines bolted direct to it but I could use via a ram mount to give even more adjustments and bolted through lever with 5mm stainless Allen screw then bottom screen adjuster is drilled slightly larger hole so Allen screw head fits through and still allows screen to adjust if anyone interested I take screen off and get better photos for you all let me know
