They look mighty fine ..... there's nothing about them ones that shout at a person's eyeballs .... nothing that is visually offensive to sensitive types ....
I damaged a lower return hose on a 999 when I replaced the voltage reg with an aftermarket MOSFET. Such a tight fit that one of taller fins put a little slice in the hose. The bike had also sat for the last eight years nearly unused. So instead of looking for OEMs, I got some Samcos for the 999 for less than US $200. Thought that was cheaper than OEMs would be and didn't want used. I do have some worries about the Samco longevity and retaining good fit on the inlets/outlets.
After a delay due to zero stock (BREXIT) these have arrived even though increased in price by 8% (Ukraine war)- they're still almost 50% less than Samco!. Look like good quality -definitely a good recommendation - thanks @cookster.
They’ll do. I fitted the same ones to my 988S but in red. You won’t go far wrong with them but I did have to trim a couple of them down to get a perfect fit.
I read somewhere that Samco hoses aid fluid flow significantly and can positively impact cooling by 10%. Might have been in a Samco catalogue mind you
