1200 DVT Snapped Chain
Discussion in 'Multistrada' started by tater, Jul 22, 2018.
  1. Lucky then, when my multi one snapped, took out all the plastics, large chunks out the swing arm, cuts in the crank case and a massive bruise on my arse, as well only staying on the bike by more luck than judgement. 70mph right hand bend when it locked the rear twice in short bursts then flew out on to the road causing the above damage. :(:oops:
  2. Wow sounds like I was lucky, I was heading up carter bar on the borders, not particularly heavy on the throttle and it just felt like I hit a false neutral. No bangs clangs or crashes, just loss of drive.
  3. can anyone confirm the chain width, getting a couple of conflicting numbers, I believe it should be 530?
  4. Standard is 530
  5. Cheers Bradders!
  6. What bradders said. 530 at 108 link as I recall
  7. Hope you did the lottery that week Wayne :eek:
