So......this missing plane.
Discussion in 'Lounge' started by El Toro, Mar 17, 2014.
  1. That thought had crossed my mind too.
  2. I think it's hidden somewhere
    Surely something would have been found somewhere by now
    I think it's in Kazakhstan though for what reason I don't know
  3. Putins probably taken it, he took the Crimea when he wanted it. :Arghh:
  4. BBC are reporting that a spotter plane have seen bits in the ocean.
  5. From where it was shot down? ;)
  6. All this talk of mobiles being turned off.
    Do some really think a mobile will work more than 5 or 6 mile offshore let alone at 35000 feet 1500 miles away from land lol
  7. I understood that the GPS aspect of the phone worked by communicating with satellites.
    I presume those searching have explored all possibilities, so anything us lot come up with has already been thought of!
  8. Or that finding a bit of metal in that size a piece of water is easier than spotting a needle is an EU stockpile of hay
  9. two survivors found, Flo Ting and So King Wet, both picked up this morning i believe..
  10. They also found Bob Bing
  11. I am missing something so far on news all they talk about is possible debris found, no confirmation they are 100% debris from that plain, no pictures yet Malaysian gov says yep that is it. Did I miss part of the news where they said that someone got to the area, fished the pieces out and confirmed yep that is that?
  12. Theyll probably find robert maxwell on a boat
  13. Pretty sad really whatever happened as a lot of people died.
    I don't think it's a conspiracy though, things like that are way too hard to cover up with so many people involved. It only takes one to disagree and tell someone else and the proverbial cat is out of the bag. Plus you have to believe that anyone in the government/military is competent enough to do it in the first place...
  14. Phones 'see' GPS satellites: it's a one way conversation. You can read the tracking data from a phone, but only over a mobile network, which isn't there over the sea.
  15. My moneys on cockpit fire.
    Crew disable devices to try to put it out,or fire affects said devices.
    Controls are damaged and they try to fly it using the Flight Management computer
    Only 12 minutes of emergency oxygen,crew/passengers lose conciousness and the bloody thing flies itself until the fuel runs out.
    This one hasn't been solved yet,and it happened on the ground:
    An Egyptair Boeing 777-200, registration SU-GBP performing flight MS-667 from Cairo (Egypt) to Jeddah (Saudi Arabia) with 291 passengers, was preparing for departure at gate F7 with the passengers already boarded when a fire erupted in the cockpit causing smoke to also enter the cabin. The crew initiated an emergency evacuation. 5 occupants received minor injuries in the evacuations. Emergency services responded and put the fire out. 2 fire fighters were taken to a hospital for smoke inhalation. The aircraft received substantial damage, the fire burned through the right hand side of the cockpit leaving a hole of about the size of the first officer's side window in the fuselage just below that window.
  16. You really believe that lol !!
  17. The thing is, if skullduggery is afoot, who shot it down then?
    It appears to be in the Southern Indian Ocean or what's left of it.
    Or is that all a red herring and they deliberately threw stuff out the plane to hide their true intentions, like the submarines putting up an oil slick to fool the destroyers in the WWII war movies?
  18. Australians!!!!
  19. Blame the Ozzy's I like the new rule :)
    For me all this talk about debrees and yet they are not able to fish even one piece out WTF, smells of something else going on.
