Spare Part Mongrel
Discussion in 'Builds & Projects' started by ducati dad, Jun 8, 2018.
  1. It will be using a complete set up from a 1098.
    Dash
    Sensors
    Loom
    ECU...m197 would be nice
    Sure, it will need recapping, ideally on a dyno.
  2. Got a m197 now...:upyeah:
  3. Any update pictures?
  4. Testing...
  5. So, I want to run a cable from the battery under the seat hump, to the starter solenoid and then the s/motor. Also, an earth from battery to the engine earth bolt. They will be about 35 inches long[ish].What gauge cable should I use? I was looking at 8.5mm2 rated at 63a. The engine is an 888cc.
  6. Thanks Sev, what would be the lowest rating you would suggest? Just thinking of the need to hide the cable as much as poss, as there is no fairing.
  7. Thanks Sev, I appreciate that...:upyeah:
