Splitting Casing - Help
Discussion in 'Supersport (1974-2007)' started by gaz92, Mar 19, 2016.
  1. Gaz, youve caught that plug in time! That bearing is the one Ive had trouble with. They seem to get notchy quite easily, it should be a SKF 6004 C3.
    The bit you are pointing at is the oil pressure release valve, it should have a spring behind it
