Sprag Clutch Replacement
Discussion in 'Sport Touring' started by indiecourier, Jul 17, 2017.
  1. For the OPs info, the alternator nut on the ST4s should be replaced every time and torqued up to 270Nm with engine oil as a lubricant, according to the workshop manual. A bit of Loctite wouldn't hurt though.
  2. hello evrybody,
    all 3 parts must be replaced or just replace the bearing and other parts only polish for good repair?
  3. Yes, you are correct, and most people use a new nut also.
