St3s Low-speed Handling
Discussion in 'Sport Touring' started by wotbus@, Jan 31, 2017.
  1. Sorry, I thought I had put the numbers in! In the example on a 4s I went from standard (15/39) to 15/43 (standard ST4).
    Not sure what's standard on the ST3 - a quick Google suggests it might be 15/42. The ST3 might use a different front sprocket type to the ST4s, though.
  2. OK thanks for that :)
  3. Googled a bit and if either of the two previous owners didn't change anything it's the standard 15/42, so I'll have to decide the increase after the initial checks are done.
  4. The good news is, it was just a slack throttle cable.
    First chance to look at it was today. Took the twistgrip apart and re-assembled it to make sure all was ok - started her up and let her run to warm then adjusted the cable out until a slight rise in revs then backed it off a tad.
    Went for a ride and it was perfect, completely changed. There's no smell of petrol now that some is used so I can only assume I put too much in then put her on the side stand while opening the garage door.
    Thanks all for the input, much obliged. :blush:
