Supersport S - Any Good?
Discussion in 'Supersport (2016 onwards)' started by PerryL, Oct 27, 2020.
  1. II think that the frame looks OK. Is that pipe a Ducati accessory that you got the dealer to fit, or did you do it yourself? Did you need to remap the engine control chip?
  2. Had mine now for 3 years.
    Very comfortable, more so than my ST3s.
    Sporty feel and look, to the point that i ride it with the lads more than the 916.
  3. I bought the Termignoni pipe via the Ducati dealer who fitted it for free. I did look at the instructions but it did seem to involve a lot of crawling about the garage floor which I am now far to old for. You really do notice the 5.5 kg weight reduction. Termignoni do supply a custom map for the pipe which the dealer installed.
  4. I also fitted the Termi to mine the first week that it became available. I don't feel the weight difference as it is only the same as a few litres of fuel and is very low down. Never bothered nor felt the need for the custom map.
  5. That is what I would be coming from. Interesting that you find it more comfortable that the ST3.
  6. Also interested in that, what height are you?
  7. My Carole is 5’5” and about 9 stone something in leathers. MR wound all but 5mm off the rear shock pre load and I sourced a low seat for her test ride. She was solid balls of the feet but a bit off flat footing and felt confident she could hold the weight of the bike stationary, if that helps. Andy
  8. 6ft on a good day , shrinking as I get older.:mad:.
    The ST is harder on the neck and wrist compared to the SS. But is still the favourite of the two.
    I've also added the Termi/upmap / air filter/ 14 tooth sprocket. The old exhaust is like an elephant compared to the Termi.
  9. I like the white bike
  10. I wish they'd clearcoat / lacquer the red Supersport (along with the non-top of the range bikes across the range).
    My 959 Corse has clearcoat matt lacquer, and so does the white Supersport, I believe.
  11. Thought they were clear coated? Mines shiney? But it has had a ceramic coating?
  12. Nope, sadly not. Run your fingertips over the Ducati decal on the tank. On a V4 or high end Monster it's under lacquer. On a lower end Monster, 959, or Supersport, it's not, and the paint is much more vulnerable as a consequence.
    The matt effect on white bikes is achieved with a lacquer, so slightly better, but the decals are still not coated.
    They don't have lacquer as supposedly as a cost saving measure, though these are still hardly cheap bikes, and other bike manufacturers manage it, and look at the bodywork area of cars in comparison.
    Lots of elbow grease.
  14. Paint finish after
    50k miles st3
    26k miles 916
    12k miles.ss
    Lots of elbow grease.[/QUOTE]
  15. Glad I had a ceramic coating then. Didn’t think cheap and Italian were words used in the same sentence?
  16. Love my SupersportS, though you may want to at least consider something from Triumph, I find my ThruxtonR much easier to just jump on & ride, if a little slower and heavier...
  17. The Supersport S is now my No. 1 choice - with Ducati hard panniers. I am tempted by the Akrapovic exhaust, just because it looks nicer than the standard. Did you fit that or was it dealer done? I presume that you needed a new fuel map?
  18. The panniers won't fit with the Akrapovic. I use the panniers but have a Termi exhaust.
  19. I think oem panniers will fit with the slip-on Akra’s but not the full high level system.
