the 'Anyone going to Boxhill today?' thread
  1. Sell it and by a Kawasaki
  2. the fuel filter is not blocked,the fuses are all good and the relay seems to be ok. The plugs were minging so cleaned them up and tried again. Still had the same thing. I have now taken the fuel system out and given everything a good clean. Injectors seemed good. Tomorrow I have to remember how it all came apart!?
  3. now looking at fireblades on fleebay
    • Dislike Dislike x 1
  4. Your taking the wrong approach, you need to offer tea/coffee a BBQ etc and see who turns up at your house
  5. no a problem martin, I don't like the colour scheme.
    I'm only looking at blades because they have to be more comfortable over long journeys. The Ducati is a killer!
  6. Mate might be selling his 954?
  7. Hmmm... £?
  8. Rob. You say it idles Ok? If stationary can you rev it all the way to end? If so in any situation or only slowly? If not does it stall asap or seems to try then brakes down, splutters and stalls?
  9. idles ok ,but the second you touch the throttle it dies. No rev's whatsoever. Just splutters and stalls
  10. Ok can you hear the fuel pump? Does it sound normal, is it any better with petrol cap open? Fuel system could be blocked, fuel pump could be damaged, electrics to fuel pump could be damaged or tank breathers. That for start. I would also check earth on loom and charge.
  11. I will try all of that tomorrow, cheers Lucazade
  12. This all went quiet, any reason for that?
  13. It's holiday season, Lucasz.
    We are out and about this weekend........
  14. [​IMG]
    I'm about. Not.
  15. Yeah - thanks for nothing, Rob!!!!
  16. It's near 40c here. Not easy at my age.
  17. What is it that's not easy at your age ??? :p:Facepalm:
  18. It's a good 20m walk to the poolside bar if I don't order at the lounger and the same distance again for the restrooms. Knowing I have to be hydrated, it's a choice. They don't like me using a TravelJohn...
  19. Whose towel are you lying on, then??
    Pretty, pretty!!!!
