The Cyclists/ebikers
  1. Dodged the rain yesterday; just got home and the heavens opened after a quick spin into the Peak on the Duc. But today was 23.75 miles on the Felt roadie near Leek which turned into a bit of an epic ride. 2.5 miles in and my friend has a puncture - front repaired, hopped on and the rear went! Then at 22 miles he got 3 more!!!! Ran me out of Scabs and scrapped a new tube; resulting in a 1.5 mile walk to the cars. New tyres and less blubber may help? Moral: go prepared!
    20200615_121051.jpg 20200615_124221.jpg 20200615_124241.jpg 20200615_124354.jpg
  2. Blow your tyres up harder, usually I just take tubes 2-3 dependent on distance. Did you ride up Axe Edge, I've done it a few times after the Cat & Fiddle. Very lumpy around Leek.....
  3. I did suggest his 14st may require a little more air than mine (10.5st); replacing 4 year old tyres would help I'm sure.
    To be fair both roads where the punctures occured were rough to say the least. Route as below - 1788ft of ascent was enough with the heat and 5 punctures and no beer stops:
  4. Kingsley & Froghall Station ^ what a picture!
  5. I run mine high 72kg's 100psi rear and 90 front, I don't suffer many punctures but might be on account of running Gatorskins
  6. Similar to my set up: lardy at the mo at 66kgs. Running 100psi front & rear but no Gators (yet); not going to tempt fate.....:rolleyes:
  7. My son and I recently both bought bikes which came with clip pedals that neither of us need.
    Both sets are in perfect condition, never used by us and with no damage, just a couple of tiny scratches.
    Putting them on here if anybody is interested in buying either set.
    Shimano SPD PD-R550 SL - retail at Halfords £45.00 - for sale at £30.00
    Shimano PD-M520 retail at Halfords £30.00. For sale at £20.00
  8. Anyone on here has a rear wheel 5 speed, with a drop out of 120 mm 700c lying around? For vintage Peugeot Road race bike, all the new stuff has a much wider drop out, many thanks!
  9. You could Cold set the chain stays to take the newer wider hubs, the problem with old school is it's ££££££.
  10. Thanks, I did hear that, but is it that easy?
  11. It is that easy, there are differing opinions on doing it. I would cold set a steel frame they’re flexible enough to do it IMO.
  12. Perfect evening for a ride last night .
  13. It's amazing what's on your doorstep to ride, and most people don't know it's there! . Rode a bit of the pilgrims way last night, was great .
  14. 2MpI8Dw85HQ1tZq7wxm_JX-D66MDyf_OEUVAi-v6fWA-2048x1536.jpg I've worked all the way through lockdown, I've had all my trips cancelled and no hols planned for now. The devil makes work for idle hands, hence a spend... It's a cracking thing to tear about the woods on
    • Like Like x 8
    Kingston 25
  16. Blimey Chris, isn’t it a bit hot for that?
  17. yes, made a mistake, got a bit carried away. :)
  18. I was supposed to be flying to Portimao today, so I though I try and simulate the full Portimao experience and go out, get knackered, hot sweaty plus a pounding headache...:upyeah:
    47k around the Cotswolds. That little stream is actually the Thames.
    Also, found another old railway, thanks Dr B!
    IMG_1744.JPG IMG_1745.JPG IMG_1747.JPG IMG_1748.JPG IMG_1749.JPG IMG_1750.JPG
    #699 Nelson, Jun 25, 2020
  19. 36k today.
    I can confirm tyre slime is shyte!
