Timing Belts ... The Kiss Of Death
Discussion in 'Ducati General Discussion' started by oldtech, Aug 1, 2020.
  1. Oi!, german pish has made the man i am today. (rubbing hands gleefully)
  2. I bet it has :p well done for entrepreneurial skills :upyeah:
  3. meh, i just fix em. had i been the designer. i wouldn't of changed a thing....:innocent:
  4. Same as on the Porsche 928 V8....if spending big money changing that long belt it's prudent to change the water pump while in there!
  5. i refuse to do them now unless the full kit is fitted. i wont check em either. its do it all or not a tall.
  6. For a handy visual guide, the belt on the right was changed at the right time. The one on the left slightly too late.
    • WTF WTF x 1
  7. Oh fook............
  8. The handbook for my 907ie says the belts should be changed at 12,000 miles but makes no mention of time. This is dating from the early 90's and it seems that time between changes wasn't a consideration then. The previous owner bought the bike from the original owner when it was a couple of years old and had dutifully followed the service instructions in the manual. Consequently, when I bought the bike in 2012 at 29 years old and with 26,000 miles it had only had two belt changes in its lifetime.
    I do about 1,000 to 1,500 miles a year with this bike but now change the belts every 3 years. I'm sure they'd last much longer but why risk it?
  9. I think you are misunderstanding the desmo valve system @finm. They are actually much easier to turn over than a conventional valve spring set up because of the far lighter return springs. A desmo engine will run without any valve springs but the springs are there to enable easier starting and improved idling. The loads on a cambelt in an engine with conventional cams and springs will be much higher.
  10. I've had 3 belts snap over the years, Ford diesel...bent valves, Renault diesel....bent rods, and an 851....bent valves (15000 miles)
    • Dislike Dislike x 1
  11. I've seen a good few belts that failed , and plenty more in pictures , but haven't seen one that simply snapped ,
    without clear evidence of fraying or other physical damage , prior to the failure
    and not talking about Ducati belts in particular .... cars , belt-drive Harleys .... DAF Vario-matic anybody ?
    .... now that is a proper odd-ball of a transmission .... :bucktooth:
  12. Not unsimilar to the Triumph Tina scooter.
  13. no, not misunderstanding. miss wording.
    smaller pulleys tho a fraction of the effort required to turn a desmo camshaft.
  14. A'richt. I'll let ye aff. ;)
    I see whaur ye're comin fae tho. Sma'r pulleys pits mair load on the belts.
  15. aye, yer too guid tae me derik. i say it awe the time.
    anyhoo. when are you gonna service my bikes? i cant be arsed and i want them done proper.
  16. Have you been reading a lot of Irvine Welsh recently ? .... he tends to have that effect on people .... :)
    " His work is characterised by a raw Scots dialect and brutal depiction of Edinburgh life. "
    Me , I'd probably need Google translate ..... :cool:
  17. Well jist bring them ower and they'll get din in nae time. Only 120 miles fae you fin, 30 mile closer than Ducati Glasgow.
  18. guid aon yah. i can drop em ower, yin at a time. mibies in the deid of wynter an its affy guid o you to do it fir no charge as well.
    :D
  19. Nah. Nah min. Double charge fir West Coasters but ah'll let ye aff wee the disposal fee fir yir auld engine ile :p
  20. My only experience was a 2000s Capri that snapped a belt. Got away with it with nothing wrong other than the belt needing replacing. Was about 2k miles over the recommended mileage. On cars, I will always change on mileage.
