749 Timing Belts
Discussion in '749 / 999' started by mattyboy 38, Mar 1, 2016.
  1. Thinking again turning it forward at the wheel does turn it back.
    No sleep for me tonight.
  2. You just about have it, after fitting the new belts , set tension on horizontal l then turn engine 270deg and set vertical, then turn engine a few turns and check again using the same method.
    Steve
    #22 Birdie, Mar 29, 2016
  3. I thought you did horizontal 1st?
    Why 2 TDC and why slightly different tensions (or so it seemed)?
    #23 Cream_Revenge, Mar 29, 2016
  4. So actually I am out. If it's vertical then 270deg to horizontal then that must match horizontal then 90deg for vertical?????
  5. you should ave been horizontal/90 deg hours ago... what you on? :)
  6. Right, looking like one TDC is compression stroke and the other is exhaust. This will result in the valves being either open or closed at TDC.
    What I'm not currently sure on is if turning the rear wheel forward so the main cam turns 270deg to vertical TDC puts it on exhaust or compression. Or of it actually matters.
  7. 99mhz :Wideyed: bit on the tight side there Creamy :D
  8. very hard to take you seriously toby...its ya head...:Bag:
  9. sory .. hed
  10. Maybe Creamy's tuning his bike.....................................................to a bloody radio station :Woot:
  11. lol... if id never met you id think you a cunt.... :D but I have... and guess what? :D a funny cunt though xxxx
  12. I know Chiz sorry I just can't help it :Sorry: never ought malicious though in fact I can't wait to meet Creamy he comes out with some beauties and given me many a giggle :)
  13. Turns out I got it wrong. There are 2 TDC. You want the 1st one. And if rechecking the belt in different places, 3rd, 5th, etc.
  14. Is it just Hz?
  15. Sorry I was rushing and got the horizontal and vertical mixed up, you are right. Post amended.
    Steve
  16. Shouldn't you turn it 90 to set vertical, not 270.
  17. Think I am correct on that, of course it depends which way you turn the engine, both could give the same result.
    Steve
  18. 90 seems simpler and yes, in a 4 stroke cycle, each piston will go through TDC twice. On the compression stroke all valves will be firmly closed and on the exhaust stroke, the exhaust valves will be closing and the inlets opening.
  19. Gates carbon drive app.
