1260 Trackday Multistrada 1260s
Discussion in 'Multistrada' started by Espen, May 25, 2018.
  1. 1/2 a turn for each 15kg weight, then ime back it off a half or so
  2. Update.
    Seems I wasn´t fully tightened up in the rear.
    Fidling with the menus I found "Load mode" under "Ride mode" settings. Setting "Load mode" in "Sport" to max preloads the rear spring when choosing sport. If you then outside the menu again set max "Load mode" (hold the left button down for a few secs) the rear spring preloads even more.
    I guess this will help even more with lean angle before touching pegs and foot gear-lever/brake-lever.
  3. Be careful as in slow corners there can be very little weight on the rear when you max out clearance, and tyres need to be very grippy (don’t ask how I know...). There should be four load settings: rider, rider/pillion, rider/luggage, rider/pillion/luggage
  4. Bit confused as i was led to believe that the multi so far as not got downshift autoblip. Am i wrong. please advise.
  5. It does. The 1260 has both Quickshift and autoblipper.
  6. Nice... and great tyre wear
    What pressures did you run?
  7. 2.1 bar on cold tires front and rear
