1299 Trackday Prep
Discussion in 'Panigale' started by bradders, Aug 11, 2023.
  1. Assuming Panigale V4 - Harder than it should be with that filter arrangement.... and the very low torque setting for the sump bolt (I'm surprised it stays in!!)
  2. 1299 twin
  3. Ah OK - see you at Silverstone I hope.
  4. When you change the oil, only bring it back up so it's level with the bottom line in the sight glass otherwise they have a habit of breathing fairly heavily which can cause a bit of a mess. Drop the ABS setting down to level 1 so it's front only otherwise the ABS can pump the rear and cause fluid leak
    • Love You Love You x 2
  6. @bradders it’ll be nice to see you buddy, mx great to see you out on track :upyeah:
  7. Defo. Been too long!
