996 Translogic Micro Dash Carbon Fibre Mounting Plate
Discussion in '748 / 916 / 996 / 998' started by Addipops996, May 2, 2014.
  1. Just look out for a used one off eBay like I did.
  2. I would recommend using 3mm carbon sheet, I used 2mm and really has to much flex with the amount of cut outs I have. That said it does take a good amount of vibration out due to this.
    I did a fair amount of research regarding vibration mounts/what I would use to space the two bits of carbon apart. Eventually made some out of ti we had kicking around at work, the vibration rubbers on the back of the dash are sufficient enough.
    The wiring is a doodle. I personally didn't bother with a new loom, just used the existing as know I will never use the old clocks again.
  3. Cheers! Ive been looking out on ebay but they are rare as hens teeth 2nd hand. Will check out the 3mm carbon.
  4. I also fitted "anti-vibration washers" ie, rubber washers, between the carbon and the dash when mounting it to also help dampen some of the vibrations out. These were 99p for about 50 from Maplins, so if you want some PM me your address and I'll stick a handful in the post for you!
  5. Now that is a strange shop!
  6. I have a detailed pdf drawing for a nice dash mounting, pm me if you want a copy. :upyeah:
  7. Hi and tanks ; my email is [email protected] I don't known how to pm you ok tanks again red 998
  8. Hi mate, sorry...no longer have the plans, in amongst thousands of emails with no chance of ever finding them again.
    Tom
  9. Ok no probs
  10. Tanks to everybody that as helped me for the info and the rest never felt so welcome and put it in right direction .amazing people here BIG tanks guys
