749 Under Slinging Rear Caliper Mount
Discussion in '749 / 999' started by Chris.King1, Aug 18, 2015.
  1. its mine !!!!!!!!!!
    :Rage:
  2. ive got one but cant help with make or brake line info, was fitted when I bought her
  3. I got one from MVS Performance (as Chris.King1 mentioned) in Germany:
    Brake Caliper Bracket Racing Ducati 749 999, 99,50 €
    Choice of 5 Colour finishes too.... (If that is your thing..!)
    Used the original brake line - just adjusted the routing by the swing arm pivot. Don't be surprised if the hugger screws snap off if you try to remove them - they will be more than likely fairly corroded in there.
    Nice quality and arrived pretty quickly.
    (I always liked the 888 SP5 lower rear caliper and the ZXR400 was similar...)
    Cheers,
    DD
  4. No flies on @RickyX quicker off the mark than Usain Bolt
    Yer snoozer yer lose @cherod
  5. You snooze, you loose :(
  6. zzzzzzzzz:(
  7. For someone not on here often,mold Ricky banged that in quick, 9pm on a sat night 3 mins after posted....
    Maybe you could copy it and make your own
  8. done deal in 7 minutes,,,, what chance has a guy got !!:Arghh:
    if i had one i could copy it, but hard worth effort if they are av for £35..
  9. Sorry guys, complete fluke on the timing last night! As Bradders said though...gotta be in it to win it!
  10. Go buy one froma performance shop, bet there is a zero at the end of that price ;) especially if it has Harris on the front...
