V4 Tyre Pressures!
Discussion in 'Tyres' started by Chillo, May 24, 2018.
  1. So 28 cold gives me 34 hot.
    Tyre really fooked now and sliding around loads but more due to being worn out.
    200/60 slick is 24-27 hot, -3 for cold
    So maybe need to drop it to 24 cold
  3. still not 100% with the correct rear pressure for when pushing it on the road! Currently on 26 cold and that's giving me 33 hot. Feel like I should go lower still?!
  4. Too low cold which is why you are getting a 7 degree increase with heat. 1 or 2 higher psi cold should give you about 32 psi hot. Counter intuative I know but rule of thumb, too low a pressure will heat the tyre too much, too high a pressure will make the tyre too cool. Andy
  5. but 28 gave me 34 hot?
    track temp is 26 hot so surely I need to be about +3 from that hot?
  6. Tyres can be sensitive to small changes. If you have tried 26 and 28 cold, try 27. I have all this to come when mine arrives and I've only just cracked the Metzeler Racetec SC3 pressures on my 1098R after 9 trackdays ! Andy
  7. I’m ok with track temp @26 hot (20 cold).just trying to get the right temp for fast road use! im guessing it’s needs to be around 28-30 hot for fast road.
