Wd40 And Other Similar Products - Any Strong Opinions ?
Discussion in 'Lounge' started by oldtech, Dec 14, 2019.
  1. Love that Fin...brilliant....
    AL
  2. yeah you’d think so......and yet
    • WTF WTF x 3
  3. Our friends from across the pond swear by this for loosening stuck fastenings. 288DF2CE-4AA4-4145-BD08-DADACC53F871.jpeg
  4. I use this for things that leave a sticky residue (not that!). Makes short work of the sticky crap left over from old wheel weights and gets rid of tar etc. Make sure you wax afterwards to protect your paint again!
  5. GT85 for general degreasing and cleaning because it’s cheap!
    Brake cleaner for it’s proper purpose - and getting stains out of carpet and fabrics because it contains the same ingredient as dry cleaning fluid!
    And something I learned from a very experienced Mechanic and racer this year - don’t use mineral based lubricants anywhere near rubber! It makes it swell and ruins seals! So WD40 - kerosene based and most normal mineral oils and lubricants will ruin all of your seals and grommets!
    Use this instead
    Before working with a proper mechanic I had no idea how many specific types of grease there are and why using the wrong kind will cause you problems down the line - I didn’t take it all in but he also used Moly grease on all suspension pivots and joints.
    • Useful Useful x 2
  6. General cleaning & cheap is the domain of Mr Sheene & Pledge. Pledge is especially helpful if you're cleaning the bike in the house 'cause the smell is less likely to get you into trouble!
    Thanks for the tips re carpets cleaning & red grease though!
  7. I’ve never used pledge to clean my chain in the house...... but I’m going to give it a go and see what happens! :joy:
  8. I just can't get Shell out of my mind for some unknown reason.
  9. Oops I haven't tried the chain either. It loosened up a lot of road crap/ grease etc on the bottom om my crankcases today though! With the fresh smell of Jasmin!
    #29 Jez900ie, Dec 15, 2019
  10. Too right! Lets focus?
  11. Cmon guys, hardly fair to keep re-posting the photo, it’s pretty obvious that her shorts had slipped off accidentally and she was unaware, she’ll be properly embarrassed if she sees that image!
  12. 8CB805D0-4454-4766-B269-89B2A3DD0A0D.jpeg Now no one will recognise her :innocent:
  13. I like using Interflon Fin Lube TF
    Not for the Scottish fella on here tho..
  14. Just use diesel.
