Well shes almost done :D
Discussion in 'Ducati General Discussion' started by BISH748, Feb 17, 2013.
  1. Hi Dan,
    my bike came with the two clips already fitted, i did look into getting some new ones from a couple of ducati parts
    places, but they were unable to help, my clips go round 45mm pipes but my akrapovic ones are 50mm, so had to use
    longer M5 screws, someone on here may know where there available from though
  2. Thanks for letting me know. I will continue with my research. Cheers, Dan
  3. Mine aren't like that, they look like modified jubilee clips ?
  4. have a treaded insert in them, i suppose they are for pipes with no welded luggs on, which mine did underneath? , prob didnt want to smaller type heat shield on there, anyway removed from mine as when i put the mono unit on and removed the rear foot pegs, noticed there was a wear mark on it, so bought a conquest one
  5. Ooo, that looks like a nice easy way to fit the larger/long heat shield but be able to remove it to put normal one back when I use the rear foot pegs. I did think the long heat shield would cause an issue with the rear foot pegs. Thank you for adding that post Kev, it is a massive help! regards Dan
  6. Hi bish748, Bike looks really good. you've put a lot of hard work and effort in and got a great result.
    I had a new 748sp back 97 and had it for 5 years it was great fun to ride.
    lapman
