What's A Good Length Security Chain To Get?
Discussion in 'Clothing, Gadgets & Equipment' started by dubcat, Sep 2, 2016.
  1. Where did you place the anti pinch pin on the 848?
  2. Just through the rear wheel spindle, I do the same on the 1299.
    I've put foam on the mushroom end so it doesn't scratch the wheel.
  3. That's odd, previous poster said that they say on the site that pinch pin wont for through 848. What size pinch pin did you get? I will get the same :)
  4. There is a school of thought that says get the shortest chain you can get away with, the idea being a shorter chain is harder to move about to make cutting easier. It is of course also lighter which is useful if you need it to be portable...
  5. Agree. Also you should try to keep it off the floor.
    Thing is the chain does need to be long enough wrap around street furniture.
  6. I'll measure it later.
    Been a few years since I bought it :)
  7. Thanks. On the pragmasis site it specifically says not compatible with 848
