899 Which Fuel
Discussion in 'Panigale' started by graeme4130, Jan 6, 2016.
  1. Agreed and covered earlier in the thread, I was referring specifically to the whole fuel map, Ie running a lean map etc, not ignition advance and retard. Besides this is air temp and gear dependant let alone fuel dependant .
    Guess the general consensus is people don't bother, maybe if we had 100 Octane? I thought some people were selling it
  2. I've never seen it at a pump, but I've seen octane boosters
    Not used then myself, but seen them in track cars
  3. Yeah, sounds like a great way to get yourself up sh*t creek. I have a twin charged (always think it sounds much more impressive than it is) Golf GT and I imagine if I tried to run an octane booster it would have a meltdown (literally).
    I guess what's missing from this thread though is the difference between different 95octane fuels from supermarkets etc. I know when I had the 848 because of its plastic tank there were loads of threads about them swelling up because of loads of ethanol (I think) in certain fuels, perhaps a point for discussion...
    You should think a Shell 95 pump would be good quality fuel but paying 5p a litre less for it at tesco u probably wouldn't be able to be as fussy :)
  4. Do Ducatis have knock sensors? I used to get 100 octane aviation fuel and use that in my cars, but never neat as they would run like a pig, I had to mix lower octane in with it. Because the higher octane burns at a different speed then the maximum point of ignition (maximum pressure of combustion) is not at the optimum crank angle and power will be lost.
  5. I fill depending on my riding style for the day , if taking it steady 95 if looneying then 98 ,
    Saying that never used 95
  6. I am fairly sure one the bike UK magazines ( Fast Bikes i think) did a test on V Power recently and found no noticeable performance benefits in using it. I think the test was actually arranged by Shell too.
  7. It was fast bikes yes, I'll see if I can find it later and post the findings.
  8. I tend to use 95 when I'm riding the bike more but when winter comes and there's less chance put 98 in.
  9. thanks burndownthediscos. best laugh I had all day!
  10. Mine gets anything other than Supermarket fuel.
    So BP, Shell, Esso etc. Sometimes put super in, but honestly you won't notice the difference. 9 times out of 10 it gets shell because it's my most local.
    Fuel it, ride it.
  11. A revelation! Best stop running mine on diesel :D Thought it sounded a bit rough
