Which Of These Clutch Tools Would You Buy?
Discussion in 'Supersport (1974-2007)' started by ck_uk, Aug 22, 2014.
  1. this is a real memory moment for me i'm ashamed to say, it's possible I used it on a wet clutch by now but would have to offer it up to confirm.
    EDIT - part of reply from one of the manufacturers of 'type 3' :- "The problem with the wet clutch is the case depth. It would work but it needs to have a spacer used. I think about 2 inches. The other problem is that Ducati started to use Aluminum baskets with a retainer ring. That wouldn't allow the tool to bottom out against the hub."
    #21 Chris, Aug 24, 2014
  2. Thanks, Chris........I keep looking at the tools available and they all seem to be for the six speed dry clutch engines......so does that mean the set-up for the wet clutch 5 speed version is different, IE different basket diameter / different tooth pattern etc.?
  3. I've used option 3 a few times; now got one going spare after I sold the 748... Do you want it?
  4. unless someone beats me to it I will whip the side off a spare engine and check on Tuesday AL.
  5. good morning
    i make the first one it would be less 10% = £27.27stg free p/p in uk to all on this web if bought via paypal invoice
    mike
  6. I was a great fan when you played for Southampton :upyeah:
  7. ah those where the days found i could move a bit faster on a st2
  8. I have the last one as well,works great.
    Not gonna say it last long if you would use it every day.
    Henk!!!
  9. #3 for me, but then I would say that!
