1198 Wont Start
Discussion in '848 / 1098 / 1198' started by cookster, Oct 10, 2017.
  1. if you have a multimeter you should be able to trace if the stater switch signal is getting to the solenoid.
    if it is then give the solenoid a couple of sharp taps with hammer, (or if your brave take the cover off and (briefly) short it with pair of (old & shitty) pliers to see if the starter turns
    if the starter switch signal isn't getting to the solenoid then i'd suspect the switch or loom
  2. Side stand/clutch switch switch.
    Is the green neutral light illuminated?
  3. @Nelson yes neutral light was on mate. :upyeah:
  4. Any update on this Al? Just curious if you had managed to get to the bottom of it.
  5. I took the switch apart and sprayed with contact cleaner seems to start now bud.
  6. Nice one....Thumbs up to contact cleaner :upyeah:
